I have just update the RL-ARM source fils with the 3.24 and now when I use :
FINFO info; ffind("Show.sdp",&info);
I have an Dabt_Handler.
What is the problem ?
Is everything rebuilt after the update?
In my project yes.
We have already found and corrected this problem. The fix will be available in the next release.
The ffind() function tries to convert the filename to upper case. Because it is located in R0 section, a Data abort is generated.
As a temporary solution, please use the filename located in RW section.
FINFO info; char fn[128]; strcpy (&fn,"Show.sdp"); ffind(fn,&info);
Franc
