start debug session nor flash device failed
I want to connect a NOR flash device to the AT91SAM9260 controller tzo boot from it.
At the moment I'm using a device from spansion, because they use nor flash devices where I could read without sending an command to the flash.
The nor flash device has a sleep time (120ns) - but the processor itself is able to boot from the flash. But when I try to start a debug session I get always the error "memory missmatch".
I've one programm which is running in the internal RAM, transmitting commands (write, CFI) to the flash. After I started this programm I'm able to write a new programm to the flash and then I could start the programm (debug session). Another try after that one will fail....
I'm not sure where could be the problem.... Maybe you will have some hints for me...
Here's my debug initialization file:
DEFINE CHAR Setup;
DEFINE INT  Entry;
DEFINE LONG PMC;
DEFINE LONG PIO_SD;
DEFINE LONG MATRIX;
DEFINE LONG SDRAMC;
DEFINE LONG SDRAM;
// Memory mapped peripherals address definitions
PMC    = 0xFFFFFC00;
PIO_SD = 0xFFFFF800;
MATRIX = 0xFFFFEE00;
SDRAMC = 0xFFFFEA00;
SDRAM  = 0x20000000;
FUNC void Clock_Setup (void) {
  if (Setup & 0x01) {
    // Setup clock; XTAL      = 18.432000 MHz,
    //              PLLA      = 96.109714 MHz,
    //              Processor = 96.109714 MHz
    _WDWORD(PMC+   0x20, 0x0000FF01);   // CKGR_MOR: Enable main oscillator
    _sleep_(100);                       // Wait for stable Main Oscillator
    _WDWORD(PMC+   0x28, 0x20483F0E);   // CKGR_PLLAR: Configure PLL A
    _sleep_(100);                       // Wait for stable PLL A
    _WDWORD(PMC+   0x30, 0x00000000);   // PMC_MCKR: MDIV and PRES fields
    _sleep_(100);                       // Wait for Main Master Clock ready
    _WDWORD(PMC+   0x30, 0x00000002);   // PMC_MCKR: all fields
FUNC void SDRAM_Setup (void) {
  if (Setup & 0x02) {
    // Setup SDRAM Controller
    // Setup pins for SDRAM controlling
    _WDWORD(PIO_SD+0x60, 0xFFFF0000);   // Disable pull-ups
    _WDWORD(PIO_SD+0x70, 0xFFFF0000);   // Select peripheral A
    _WDWORD(PIO_SD+0x04, 0xFFFF0000);   // Disable PIO mode
    _WDWORD(MATRIX+0x11C,0x00000002);   // EBI_CSA: CSA1 support for SDRAM
    //_WDWORD(SDRAMC+0x08, 0x85227259);   // SDRAM Configuration
        //mein verwendeter sdram 32bit modus
        _WDWORD(SDRAMC+0x08, 0x85227255);   // SDRAM Configuration
        _sleep_(10);
    _WDWORD(SDRAMC+0x00, 0x00000001);   // Issue NOP Command
    _WDWORD(SDRAM+ 0x00, 0x00000000);
    _WDWORD(SDRAMC+0x00, 0x00000002);   // Issue Precharge All Command
    _sleep_(10);
    _WDWORD(SDRAMC+0x00, 0x00000004);   // Issue Auto-Refresh Command
    _WDWORD(SDRAM+ 0x04, 0x00000001);
    _WDWORD(SDRAM+ 0x08, 0x00000002);
    _WDWORD(SDRAM+ 0x0C, 0x00000003);
    _WDWORD(SDRAM+ 0x10, 0x00000004);
    _WDWORD(SDRAM+ 0x14, 0x00000005);
    _WDWORD(SDRAM+ 0x18, 0x00000006);
    _WDWORD(SDRAM+ 0x1C, 0x00000007);
    _WDWORD(SDRAM+ 0x20, 0x00000008);
    _WDWORD(SDRAMC+0x00, 0x00000003);   // Issue Load Mode Register Command
    _WDWORD(SDRAM+ 0x24, 0xCAFEDEDE);
    _WDWORD(SDRAMC+0x00, 0x00000000);   // Enter Normal Mode
    _WDWORD(SDRAMC+0x04, 0x000002EE);   // Refresh for SDRAM (at 96 MHz)
FUNC void Remap (void) {
  if (Setup & 0x10) {
    _WDWORD(MATRIX+0x100,0x00000003);   // MATRIX_MRCR: Remap IRAM to 0
FUNC void PC_Setup (void) {
  if (Setup & 0x40) {
    PC = Entry;
FUNC void GoMain (void) {
  if ((Setup & 0xA0) == 0xA0) {
    exec("g,main");
Setup = 0xF1;
Entry = 0x10000000;
Clock_Setup();
SDRAM_Setup();
//Remap();
//Download();
PC_Setup();
GoMain();
best regards
Gerd
