Serial Interrupts / printf
Greetings,
I am wanting an interrupt to occur when I receive data.
In my code - When I receive data, I set a variable and clear RI.
Then in the main part of my code I have some printf() statements.
Am I correct that a serial interupt occurs on either RI or TI being set?
Is there a way to interrupt on ONLY a receive?
My code is getting locked up. I'm thinking it's due to my printf's and interrupts.
My printf's work - when I disable interrupts.
Am I getting into problems clearing TI in my ISR - I'm guessing my printf is not complete when the code bounces back.
How should I handle interrupting on received data and using printf to display that received data?
The ISR:
void
serial_int() interrupt 4
if(TI == 1)
TI = 0;
if(RI == 1)
RI = 0;
serial_data = SBUF0;
need_serial_port_service = 1;
key_pressed = 1;
RI = 0;
TI = 0;
Sparky_
