I m using p89c669 microcontroller for my development. In my software,using two array of size [672] bytes. I use xdata,idata and also pdata which totals 1k memory, but remaining 1k memory i m not able to handle i.e. edata present in p89c669.
-How to handle and use edata or complete 2k memory of p89c669 in keil compiler.
Check the datasheet - is "edata" just different name for a specific implementation of XDATA on this chip...?
Is it like that defining as xdata itself takes care of edata when memory of xdata exceed 768 bytes. I m taking that value on hyperterminal i got garbage data if array size increases 768 bytes.
