file system case sensitive
I use Keil's file system on a NXP ARM with SD Card. I want to create filenames in lowercase, but when I initialise a string, e.g. strcpy(file_str, "myfile.dat") and do a fopen() with that name it creates a file using uppercase letters.
By chance I found that if I do a strcat after I initialised the string, e.g. strcat(file_str, "_anything") and then do a fopen() the file is created with lowercase letters.
Can someone explain this and how can I create files using lowercase letters?
