How to use MMU?
Hi, I'm using AT91SAM9260 in a printer design. I'm using RL-RTX operating system.Since AT91SAM9 contains I & D caches and MMU built-in I'd like to use it.But, all the examples provided by Keil for AT91SAM9 had enabled only I-cache. How can I use both the I and D caches and MMU? Can I use MMU with RL-RTX?
Please help me.
  • > But, all the examples provided by Keil for AT91SAM9 had enabled only
    > I-cache.
    This is because the D-cache can only work if the MMU is enabled.
    First of all, read the relevant sections in the ARM926 TRM. You will
    find that in order to enable the MMU you will have to provide a L1
    page table and have the TTB register (cp15,c2) point to it. See below.
    Of course. The question is rather: "Does RL-RTX make active use of the
    MMU, e.g. for task management?" This I couldn't answer.
    If you provide a page table, make sure it doesn't interfere with
    RL-RTX (in case it actually uses the MMU).
    An ARMv5 level 1 page table consists of 4096 entries (words, one per
    section). In a trivial situation (need MMU only to be able to turn on
    D-cache) you would provide a flat mapping, e.g. every virtual section
    maps to a physical section with the same address. Set section
    attributes (cacheable, bufferable, permissions) appropriately. This
    data structure could be stored in flash or RAM. For an MCU with little
    memory to work with, and an OS that doesn't actually use the MMU, the
    page table could stay in flash, since most of the translations will be
    held in the TLB (64+8 entries) anyway.
    Regards
    Marcus
    http://www.doulos.com/arm/
    > I-cache.
    Regards
    Marcus
