I am working on LM3S8962 and need to write a program to comunicate with PC via UART. I use Labview inline C node to write codes using ARM_Serial.c which is from Keil Software.
The file has
int ARM_Serial_InitPort (int serDevNo, unsigned long baudrate, unsigned int databits, unsigned int parity, unsigned int stopbits) int ARM_Serial_Write (int serDevNo, const char *buffer, int *length)
I tried to use them to control serial port, but it didn't work well. I used U0TX, U0RX and GND pins on micro controller to connect to a serial port in PC.
I couldn't find any information about ARM_Serial_InitPort and ARM_Serial_Write functions on the internet. Any information or tips about it would be very appreciatted.
Thank you.
Masa
Is it?
This sounds more like a Labview question to me...?
Yes, it is.
The header of the c file says
/*---------------------------------------------------------------------------- * Name: ARM_Serial.c * Purpose: For Luminary Micro LM3SXXXX microcontrollers * adapted from Template generic driver for LabVIEW * Version: v1.00 * Note(s): *---------------------------------------------------------------------------- * This file is part of the uVision/ARM development tools. * This software may only be used under the terms of a valid, current, * end user licence from KEIL for a compatible version of KEIL software * development tools. Nothing else gives you the right to use it. * * Copyright (c) 2007 Keil Software. *---------------------------------------------------------------------------*/
These codes bellow are test codes I wrote, which doesn't work. Did I make a mistake or do I need to do something else to use serial port?
//initialize serial port int ret; ret = ARM_Serial_InitPort(0, 9600, 8, 0, 10); printf("initialize-ret:%d",ret); //Write data to serial port int l = 5; int ret; char *x; x="test"; ret = ARM_Serial_Write(0, x, &l); printf("writing-ret:%d\n",ret);
So, I guess that's where you need to look for documentation on this?
Yes. But I couldn't find any information about it.
By the way, I noticed that my microcontroller which is connected to PC with USB cable creates a virtual com port in PC. And it seems that the virtual com port is receiving some data from the microcontroller instead of actual serial port.
