I get a lot of warnings when I try to compile my project.
warning: integer operation result is out of range
All these warnings are produced by the atmel register-header file provided by Keil. I can't see any kind of mistake. Is it possible to disable "only" these warning messages?
e.g.
AT91F_PIO_CfgPeriph( AT91C_BASE_PIOA, // PIO controller base address ((unsigned int) AT91C_PA31_DMARQ0 ), // Peripheral A 0); // Peripheral B
best wishes Fabian
Apparently, the warning is caused by this: (1 << 31). This expression is buried in the header files. The right way to do it is like this: (1u << 31). You could simply do a find-and-replace on the header files to get rid of the warnings.
thank you very much for the hint.
The "problem" is known, you can find the solution also in the support knowledgebase: http://www.keil.com/support/docs/3243.htm
