I get a lot of warnings when I try to compile my project.
warning: integer operation result is out of range
All these warnings are produced by the atmel register-header file provided by Keil. I can't see any kind of mistake. Is it possible to disable "only" these warning messages?
e.g.
AT91F_PIO_CfgPeriph( AT91C_BASE_PIOA, // PIO controller base address ((unsigned int) AT91C_PA31_DMARQ0 ), // Peripheral A 0); // Peripheral B
best wishes Fabian
thank you very much for the hint.
The "problem" is known, you can find the solution also in the support knowledgebase: http://www.keil.com/support/docs/3243.htm
