I downloaded the LPC2368 USB Mass storage Device example for MCB2300 demo board but doesn't work. The Windows XP doesn't recognizes the device and I don't understand if the problem is my workspace or if I have to purchase vendor IDs from web site http://www.usb.org.
Has someone used that example? Any suggestion?
What do you mean it does not work? What are your symptoms? No, you are not required to get a different Vendor ID to run this demo program. Keil has included their test Vendor ID in the descriptor files. Bradford
Thank you for your fast replay. When a connect the usb cable the following message appears: USB device not recognize
I think the problem is my workspace. Thank you again.
