Hallo
I do have some generel question when calling a function from a isr.
I do see some strange behavior when doing it, depending on compiler optimization level and code.
When calling a function from the isr, that do some float operation on some data, I get a data abort exception or a program abort exception. When running the same code with compiler optimization level 1, I get an spourios interrupt instead.?
But if I remove the floating point calculation in the function, I dont have any problems. (No exception or spurios interrupt)
I know its generally not a good idea to call function from ISR. I dont intend to do that. It just caught my attention why I get this strange behaviour? Has it something todo with calling non static function? I just would like to understand the reason...
See code sample below..
I dont use any Rtos. Im running on a LPC2103 and uVision 3.40
// ISR from the SPI.. void SPI_Isr(void) __irq { // Read the SPI status register if ((S0SPSR & 0xF8) == 0x80) { // Switch on state switch(bySPIState) { ... do stuff.... case 2: { .. reading SPI register ... // Store sample lConversionData[bChanl] = lTempConversion; // After a short time the exception occure // in the Update Update(); state = SPI_OK; // transfer completed } break; } } else // SPI error { .. error handling here state = SPI_ERROR; } // Reset SPI interrupt flag S0SPINT = 0x01; // ACK the interrupt VICVectAddr = 0; } void Update(void) { fTemp = (lConversionData[bChanl]&0xFFFFF) *0.001497268677; // mV fTemp = fTemp/150; // Is the sign bit set? if((lConversionData[bChanl]&0x200000) == 0x200000 ) // Signed? { fTemp *= -1; } protocol_UpdateData(WEIGHTCELL_MODULE, m_byCurrentChannel, fTemp, 0); }
So, if I move the code inside the Update() to the SPI isr, no problems!!
Calling the Update() i get the explained behaviour?
But I i just remove the "0.001497268677" value from the equation, no problemas?
If I remove the lConversionData[bChanl] no problems?
Why?
/Thomas
Did you check stack usage during the ISR? ISRs take place in a different CPU mode than the main program on ARMs, and this CPU mode requires its own stack space (which also needs to be initialized first).
I would suspect that either the IRQ stack isn't set up properly, or it is too small to handle the memory requirements for calling all the floating point library functions.
You are right!!!
Thanks..
