Function call in isr
Hallo
I do have some generel question when calling a function from a isr.
I do see some strange behavior when doing it, depending on compiler optimization level and code.
When calling a function from the isr, that do some float operation on some data, I get a data abort exception or a program abort exception. When running the same code with compiler optimization level 1, I get an spourios interrupt instead.?
But if I remove the floating point calculation in the function, I dont have any problems. (No exception or spurios interrupt)
I know its generally not a good idea to call function from ISR. I dont intend to do that.
It just caught my attention why I get this strange behaviour?
Has it something todo with calling non static function?
I just would like to understand the reason...
See code sample below..
I dont use any Rtos. Im running on a LPC2103 and uVision 3.40
// ISR from the SPI..
void SPI_Isr(void) __irq
  // Read the SPI status register
  if ((S0SPSR & 0xF8) == 0x80)
    // Switch on state
    switch(bySPIState)
       ... do stuff....
       case 2:
         .. reading SPI register ...
        // Store sample                         lConversionData[bChanl] =  lTempConversion;
         // After a short time the exception occure
         // in the Update
         Update();
         state = SPI_OK; // transfer completed
       break;
   else // SPI error
      .. error handling here
      state = SPI_ERROR;
   // Reset  SPI interrupt flag
   S0SPINT = 0x01;
   // ACK the interrupt
   VICVectAddr = 0;
void Update(void)
         fTemp = (lConversionData[bChanl]&0xFFFFF)
                   *0.001497268677; // mV
        fTemp = fTemp/150;
        // Is the sign bit set?
        if((lConversionData[bChanl]&0x200000) ==
             0x200000                     ) // Signed?
                fTemp *= -1;
        protocol_UpdateData(WEIGHTCELL_MODULE,
                       m_byCurrentChannel, fTemp, 0);
So, if I move the code inside the Update() to the SPI isr, no problems!!
Calling the Update() i get the explained behaviour?
But I i just remove the "0.001497268677" value from the equation, no problemas?
If I remove the lConversionData[bChanl] no problems?
Why?
/Thomas
