RTC saved ram : how to disable zero init ?
I'm using the RTC backup ram on a lpc23xx board in order to saved crucial varables.
But it seems it's always set to 0 at startup and I want to avoid that.
I'm using a scatter file and I define a rtc_ram section like this :
RW_RTCRAM 0xE0084000 0x000007FF { main.o (rtc_ram) }
I tried to use zero init at declaration , but It's always set to 0 :
volatile uc_saved_status_t uc_saved_status __attribute__((section("rtc_ram"),zero_init));
How can I bypass the init for the RTC ram ?
Thanks in advance
