C161CS IAP
i would like to ask if I would be able to program an Infineon C161CS microcontroller using RS232? or is the microcontroller IAP capable?
thanks.
  • Do you have a ROM or Flash device?
    The C161CS has a bootstrap loader mode which allows you to download a program into the internal RAM of the device via the ASC0 port. This program could be made to program internal or external memory.
    The port pins of the C161CS are by default 5V CMOS compatible levels so you would need level translation from RS232 voltage levels.
