Hi friends,
I'm planning a microcontroller project which is operating in high EMI or noisily enviroment. Anyone has experience in that area please suggest which microcontroller is the best choice?
Can the uvision simulate random EMI and noise crashes?
thanks, zorx pak
:) Happy microcontroller programming :}
My suggestion is to use microcontrollers with integrated oscillator and as many of peripherals integrated into mcu's package (this depends on your project requirements). Also, wich mcu's have you used (8051, pic, arm, ...)?.
For 8051 family my suggestion is DO NOT USE THE Silicon Laboratory bits EVER . Look on theire site, wide choice, lots of code examples but they dont work with NFRP decoders.
Regards
For 8051 family my suggestion is DO NOT USE THE Silicon Laboratory bits EVER . Look on theire site, wide choice, lots of code examples but they dont work with NFRP decoders. sure they do if the design is done with concern for what they are exposed to.
I use SILabs chips in a VERY noisy environment and have zero, none, nada problems.
If you use shortcuts in a 3V3 5V mixed environment, you get what you ask for.
