uVision/51 v1.13 8051 C compiler - command-file not found
I have changed the name a folder containing a Keil C project and as a result near or at the end of the build process I now am getting an error
*** ERROR: COMMAND-FILE 'C:\GB\GSI3_R' NOT FOUND
The uVision/51 application title bar has
uVision/51 - Kaly_RDU.UV2 - [KALY_RDU.LER]
in the title bar
The project folder name is GSI3_RDU so it seems a path name is truncated to 6 characters (part of a DOS name before the tilde? e.g. GSI3_R~1 ?)
I cannot find anything in the menus in which a path or command file resembling the above would be contained. A text search of the various project files and environment variables was unsuccessful.
Any ideas where this command or path might be set?
Any help appreciated.
- GB, Toronto Ont.
