I have one Doubt how void uart(void)__irq this function call in this program..........????
#include "lpc21xx.h" // #include "lpc210x.h" #include "stdio.h" #define baudrate_uart1 0x0f //@115200;SYS_CLK/16*2*COUNT=0x0f #define sender_no "+919328178092" #define sms "Advance Technology rising company in future" #define CR 0x0D #define LF 0x0A /****************************Prototypes****************************/
void delay(void); void getch (char ch); char *gps_strchr(char *src, char ch); int gps_strncmp( char *s1, char *s2, unsigned char length); int gps_strcpy1(unsigned char *s1,char *s2); const char *uart1Puts(const char *string); int uart1Putch(int ch); void uart1_interrupt(void); void uart1_initialize(void); void check_response(char *sentence); void lcd (int length) ; void instwrt(void); void datawrt(void); void lcd_init(void); char at_get_running; char at_get_buff[160],*at_get_idx;
char response_ok=0; char lcd_buffer[20],temp123[200]; static char array1[160];
int main() {
VPBDIV=2; IODIR0=IODIR0|0x0f00fffc;
uart1_initialize(); uart1_interrupt(); lcd_init();
uart1Puts("AT" ) ; uart1Putch(CR); delay();
while(response_ok!=1) //check response for previous cmd { response_ok=0; //uart1Puts("AT+CMGF=1" ) ; // uart1Putch(CR); // delay();
//uart1Puts("AT+CMGS=" ) ; //uart1Putch('"'); //uart1Puts(sender_no) ; //uart1Putch('"'); //uart1Putch(CR); //uart1Puts(sms); // uart1Putch(26); // delay(); } while(1) {
/***************************************************************************** * FUNCTION : UART1 interrupt * PURPOSE : for data capturig at baudrate 115.2kbps * INPUTS : receive interrupt * RETURNS : none *****************************************************************************/
void uart(void)__irq { char status,temp; if((U0LSR & 0x01)==0x01) { status=U0RBR; getch(status);
} VICVectAddr=0; temp=U0IIR;
} /***************************************************************************** * FUNCTION : get_ch * PURPOSE : gets the ch from GPRS and findout gprs responses and route table information * INPUTS : passing ch receive from uart1 receive interrupt * RETURNS : none *****************************************************************************/ void getch (char ch) {
static char ch_count1=0;
if( ch_count1<150) { array1[ch_count1]=ch; ch_count1++; } else ch_count1=0;
if((ch ==LF)&&(!at_get_running)) //start of response { at_get_running = 1; //sentence being recieved flag true at_get_idx = at_get_buff; }
if(at_get_running) { if((ch== LF)&&(at_get_idx == (at_get_buff+1))) //start of response received { at_get_idx = at_get_buff; } else if((ch == CR)&&(at_get_idx > (at_get_buff+1))) //end of response { at_get_running = 0; *at_get_idx = 0; check_response( at_get_buff); } else { if(ch!=LF) *at_get_idx++ = ch; //update buffer with response on uart } }
/***************************************************************************** * FUNCTION : int check_response(void) * PURPOSE : check AT response type from response strored in buffer and * return appropriate value according to type * INPUTS : sentence: address of buffer * RETURNS :1 on success 0 on error/busy
*****************************************************************************/ void check_response(char *sentence) {
if(gps_strncmp(sentence, "RING", 4) == 0) { response_ok=1; // lcd_buffer[]={}; gps_strcpy1(lcd_buffer,"CALL FOR U"); lcd(10); uart1Puts("ATA" ) ; uart1Putch(CR); delay();
} else if(gps_strncmp(sentence, "NO CARRIER", 10) == 0) { response_ok=0; gps_strcpy1(lcd_buffer,"MISS CALL"); lcd(9); }
else if(gps_strncmp(sentence, "+CMTI:", 6) == 0) //+CMTI: "SM",16 ==cmti is receive response, sm: sim memory, 16 location number { // maximum 30 sms stored gps_strcpy1(lcd_buffer,"NEW MSG RECEIVED"); lcd(16);
//lcd(16);
} else if(gps_strncmp(sentence, "RING", 4) == 0) response_ok=1;
else if(gps_strncmp(sentence, "OK", 2) == 0) response_ok=1; } /***************************************************************************** * FUNCTION : gps_strchr * PURPOSE : Searches for the character and returns the location * * INPUTS : char *src - source string * char ch - character to be searched
* RETURNS : address location of character in string
1) I have one Doubt in the time you spent reading he posting instructions - especially regarding how to post source code.
2) I have another Doubt regarding your doubt - you have just posted unformatted source code, but not asked any question or specified what work you have done to clear your doubt before you made your post. Do you for example know what an interrupt is? You do not call an interrupt handler. You "install" it, and the processor itself will then call it when needed. Have you looked at the code samples available on Keil and installed with the compiler?
3) A third Doubt is of course the full name of your processor - it seems like a NXP LPC21xx chip. All posts to hw forums should comtain explicit information regarding your problems.
4) A fourth doubt is why you are not using the full ISR-driven serial implementation that Keil supplies, that will handle both receive and transmit interrupts, to make your application concentrate on making decisions based on the responses you gets from the modem.
Dear Westermark11, as su told in your 4th point how i use this full ISR-driven serial implementation
Plz reply
