code segment:
... EXTRN NUMBER (MAX_NUM) DS MAX_NUM END
another code segment:
PUBLIC MAX_NUM MAX_NUM EQU 8
when i assembled and linked these codes, there was an error:
Build target 'test' assembling test.asm... test.asm(13): error A28: ABSOLUTE EXPRESSION REQUIRED Target not created
How did it hanppen?
Is there anybody can help me?
MAX_NUM EQU 8
Look in the assembler manual what EQU means - it declares an assembly-time constant, not a run-time variable. The linker on the other hand processes run-time variables.
By the way: No toolset? Not related to any processor architecture? And the descriptive summary "help"?
