NAME SAMPLE PUBLIC TXTBIT PROG SEGMENT CODE CONST SEGMENT CODE VAR1 SEGMENT DATA BITVAR SEGMENT BIT STACK SEGMENT IDATA RSEG STACK DS 10H ; 16 Bytes Stack CSEG AT 0 USING 0 ; Register-Bank 0 ; Execution starts at address 0 on power-up. JMP START RSEG PROG ; first set Stack Pointer START: MOV SP,#STACK-1 ; Initialize serial interface ; Using TIMER 1 to Generate Baud Rates ; Oscillator frequency = 11.059 MHz MOV TMOD,#00100000B ;C/T = 0, Mode = 2 MOV TH1,#0FDH SETB TR1 MOV SCON,#01010010B ; clear TXTBIT to read form CODE-Memory CLR TXTBIT ; This is the main program. It is a loop, ; which displays the a text on the console. REPEAT: ; type message MOV DPTR,#TXT ; repeat SJMP REPEAT ; RSEG CONST TXT: DB 'TEST PROGRAM',00H ; only for demonstration RSEG VAR1 DUMMY: DS 21H ; TXTBIT = 0 read text from CODE Memory ; TXTBIT = 1 read text from XDATA Memory RSEG BITVAR TXTBIT: DBIT 1 END
When I assembled and linked this program, I watched the start address of STACK segment is OxO6A, why not the 0x08H?
