Hai all, My program goes to infinite loop even though there is no while(1);
void main() { uchar8_t ISMCheckResult; CKCON=0x04; DR=1; delay(50000);//Power on delay for testing purpose enableLatch(0x00,0,7); delay(40); readBuffer(0,7); ISMCheckResult=IP_Sensing_check(); Display(ISMCheckResult); }
It stays in following Idata Loop....
IF IDATALEN <> 0 MOV R0,#IDATALEN - 1 CLR A IDATALOOP: MOV @R0,A DJNZ R0,IDATALOOP ENDIF
what is the problem? The functions in main I have used is very simple as follows...
void enableLatch(uchar8_t lactchValue,uchar8_t start,uchar8_t end) { uchar8_t index1; DR=0; for(index1=start;index1<=end;index1++) { XBYTE[latchAddressTable[index1]]=lactchValue; } DR=1; } void readBuffer(uchar8_t start,uchar8_t end) { uchar8_t index=0; DR=0; for(index=start;index<=end;index++) { Hardware_Buffer_Value[index]=XBYTE[bufferAddressTable[index]]; } DR=1; } uchar8_t IP_Sensing_check(void) { uchar8_t Flag=0,i; DR=1; for(i=0;i<INPUT_BUFFERS;i++) { if(Hardware_Buffer_Value[i]!=0) { Failed_Latch_Location[i]=ONE; Flag++; } else { Failed_Latch_Location[i]=ZERO; } } return((Flag>0)?ONE:ZERO); } void delay(uint16_t n) { uint16_t i; for (i=0;i<n;i++); } void Display(uchar8_t Input_Sensing_check_result) { uchar8_t index; SCON = 0x50; TMOD = 0x20; TH1 = 0xFA; TR1 = 1; TI = 1; DR=1; /* for(index=0;index<NO_OF_LATCHES_CHECK;index++) { printf("\nBuffer Contents %2bd %2bx\n",index+1,Hardware_Buffer_Value[index]); } */ if(Input_Sensing_check_result!=ZERO) { printf("\nChannel checking Failed\n"); for(index=0;index<NO_OF_LATCHES_CHECK;index++) { if(Failed_Latch_Location[index]!=ZERO) { printf("\nLatch/Buffer %2bx Failed\n ", index+1); } } } else { printf("\nChannel checking OK\n"); } }
The output is coming correctly but it goes to infinite loop as if while(1){ //functions} is used....what is the problem kindly clarify me..
... and you're sure of that? I ask because your other description of the problem is much less specific:
What are the exact symptoms?
Oh, and what's the value of IDATALEN? Did you make any modifications to the startup code?
