Why step into next instrution with TD3 different value?
First:
#include <AT89X51.H>
unsigned int  TD3=0;//
void t0(void) interrupt 1 using 3
TL0=(65536-50000)%256;
TH0=(65536-50000)/256; //6MHz
TD3++;
void main()
{//1
TMOD=0x11; //
ET0=1;
EA=1;
TR0=1;
while(1)
while(TD3<=18000); //
TD3=0;
}//1
Secondly:
#include <AT89X51.H> unsigned int TD3=0;//
{ TH0=(65536-50000)/256; //
TD3++;
} void main()
{//1
TMOD=0x11; //
ET0=1;
EA=1;
TR0=1;
while(1)
{ while(TD3<=18000); //
TD3=0;
} }//1
TD3 counter limited all 18000.By the first way, TD3 counted to 18000 then step int TD3=0; .But , by the second way , TD3 counted only to 17920 then step into TD3=0; .Why did this happen?
Thanks.
  • You are using an 8-bit processor. The processor is incapable of performing an atomic test of a 16-bit number, just as your 16-bit assign of the timer registers has to be splitted into two 8-bit assigns. The test is performed either low byte before high byte or the reverse - and if the variable gets incremented in-between, you get into troubles.
    Why not let your interrupt perform the compare/reset, and set a flag?
    You also have to think about this problem when you reload the timer in your interrupt handler - what happens when you assign just the low or the high part of the timer value?
