cx51/lx51 running under wine on linux?
searching this forum, i see posts referring to success with the keil tools under wine, but they're several years old.
i have a licensed copy of CA51. i'd like to run the individual command-line tools from a unix Makefile. i've successfully been able to compile, and assemble, but when i run LX51, it tells me that:
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: DEA5H BYTE (2783%) *
and
*** ERROR L257: EXTENDED LINKER REQUIRES UPGRADE TO PK51
if i remove or edit the LIC0 line in TOOLS.INI, i get different, license-related errors when compiling, so i'm reasonably sure my license is install correctly.
am i doing something dumb? what would normally distinguish an eval copy of lx51 from a "real" copy?
paul
  • bad form, replying to my own post.
    perhaps i'm using the wrong linker? bl51 seems to work, where lx51 does not.
    should/could there be a licensing difference between these two?
    assuming no licensing difference, why would one choose lx51 over bl51, or vice versa?
    paul
    paul
