Hello
I develop an application with the STR9-Comstick. The idea is to control the I/O ports with a program in Visual Basic through the USB-B connector near the pins of I/O ports. Which dll use for that for the enumeration ? The first application will be to generate a TTL signal for differents frequencies through a pin of the I/O ports. Is there a way to program it in C (TTL signal) for the STR9 ? And so the program in VB ?
use the available USB HID (human interface device) samples (available at your installation) for the STR9 to create the interface towards the PC side. I have never interfaced with a device with VB, but you can probably find some sample code on google!
Thanks for your answer but i don't see which driver use for the enumeration for my application.
Regards.
Vlieghe Guillaume
on windows side, you don't need to worry. using the correct API in the proper manner will address the right device driver for you. maybe you can find code samples here? http://www.lvr.com/usbcode.htm
