PPP NULL modem Dial-out
I'm trying to setup PPP over NULL modem. Till now i can dial-in to my keil MBD2100 with LPC 2129, over a NULL modem cable in windows and get my http-server to show my index.htm.
When i setup incoming-connection in windows and use the following code, nothing happens:
<snip>
init_TcpNet();
init_modem();
ppp_connect(NULL,user,pass);
while(1)
{ timer_poll(); main_TcpNet();
</snip>
Akshat
  • There is an example which shows you how to use PPP client. It is located in: ARM\Boards\Keil\MCB2130\RL\TCPnet\LEDClient folder. This example connects via null-modem cable to another MCB2130 evaluation board using PPP. You can use it as a template for your own application.
    2nd step is to properly configure your PC as a PPP server.
    Franc
    Franc
