Hi, Can anybosy who have worked on FX2LP help me? I'm writing firmware (converted from bulkloop)of slave FIFO mode w/ FX2LP(Cameleon). I'm using AUTOOUT mode w/ EP2, so, regarding UZ_USB_TRM, i don't think I need any codes in TD_Poll. If anyone finds any mistakes, please let me know, thanks.
void TD_Init(void) // Called once at startup { CPUCS = ((CPUCS & ~bmCLKSPD) | bmCLKSPD1) ; IFCONFIG = 0xe3; // slave FIFO SYNCDELAY; REVCTL = 0x03; SYNCDELAY; EP1OUTCFG = 0xA0; //Active Endpoint1-out , type = BULK (E610) EP1INCFG = 0xA0; //Active Endpoint1-in , type = BULK (E610) SYNCDELAY; EP2CFG = 0xA2; SYNCDELAY; EP4CFG = 0x00; // invalid SYNCDELAY; EP6CFG = 0x00; SYNCDELAY; EP6CFG = 0x00; SYNCDELAY; EP2BCL = 0x80; // arm EP2OUT by writing byte count w/skip. (E691) SYNCDELAY; EP2BCL = 0x80; SYNCDELAY; PINFLAGSAB = 0x00; SYNCDELAY; PINFLAGSCD = 0x00; OEB = 0xff; // PortB All Output OED = 0xff; // PortD All Output FIFORESET = 0x80; SYNCDELAY; FIFORESET = 0x02; SYNCDELAY; FIFORESET = 0x04; SYNCDELAY; FIFORESET = 0x06; SYNCDELAY; FIFORESET = 0x08; SYNCDELAY; OUTPKTEND = 0x82; SYNCDELAY; OUTPKTEND = 0x82; SYNCDELAY; OUTPKTEND = 0x82; SYNCDELAY; OUTPKTEND = 0x82; SYNCDELAY; EP2FIFOCFG = 0x10; // FD[7:0]->PortB SYNCDELAY; IOD = 0xe0; // Set a Mode }
Follow this example on the Technical Reference Manual
ez_usb_r___technical_reference_manual__trm__14.pdf p9-23 "Figure 9-28. TD_Init Example: Configuring AUTOOUT = 1" for EP2
Tsuneo
