First at all, I would like to use keil Vision but with GNAU GCC COmpiler. I have downloaded the and installed keil. Then, I have installed the file that is in this website. But I haven't done anymore. With this steps, is it all well or do I have to do anymore?
Finally, I have to develop an application with LPC2129. I have a code that I know it works. But I can't compile because it can use the libraries .h...What can I do?
I have tried to compiled this code with another programm, and the result is good, no errors!
"I have tried to compiled this code with another programm, and the result is good, no errors!"
Why not just stick with that program, then?!
Keil seem to have dropped all mention of GCC from their ARM products section; it was never "supported", and now it isn't even mentioned - that sounds like just making life unnecessarily difficult for yourself!
There are plenty of GCC-based tools about if you really must use GCC; if not, why not just use a complete Keil toolchain?
"I have tried to compiled this code ... the result is good, no errors!"
Note that there is a big difference between compiling with no errors and actually having a good program that actually runs & functions correctly...
Hello Nazandy Porez,
GNU support is now available via CodeSourcery. See: http://www.keil.com/appnotes/docs/apnt_199.asp
Best Regards, Martin Guenther
