Hello, I am sorry to bother you again :(
(again the STM32 Cortex)
I have found the example SD_File, but i can't compile it, i believe i have the right license, but get 2 errors: File_Config.c(13): error: #5: cannot open source input file "File_Config.h": No such file or directory
and it can not find FSCM3.LIB
Must i install more than the keil setup file for RL libraries?
Kasper
Flash File System is part of the RealView Real-Time Library (RL-ARM) which is a separate product.
http://www.keil.com/arm/rl-arm/
