Hello, I teach Computer Architecture at the University of Washington Bothell campus. I'm teaching the ARM 7 architecture for the first time and this is the first time I'm using the uVision toolset. I'm having trouble getting simple programs to assemble and link so I can single step them in the ISS so I can do simple demos for my students and have them do simple programming assignments. I seem to be stymied by the linker. Can someone send me a simple skeleton that I can use to create short programs that I can use?
What I've tried so far. I got a sample program from the ARM ADS 1.2 CD-ROM that I have (shown below). I added the label, __main and place the pseudo-op instruction, EXPORT __main. That seemed to fix one error and introduced another one. I seem to always be one error away from getting it to build. I included the startup.s file in the project. Here is the error message that I receive:
ASM_test.axf: Error: L6218E: Undefined symbol __use_two_region_memory (referred from startup.o)
Thanks in advance for any help that you could provide.
Arnie
Here's my program code:
AREA Jump, CODE, READONLY ; name this block of code CODE32 ; Following code is ARM code num EQU 2 ; Number of entries in jump table ENTRY ; mark the first instruction to call ;removed start __main MOV r0, #0 ; set up the three parameters MOV r1, #3 MOV r2, #2 BL arithfunc ; call the function stop MOV r0, #0x18 ; angel_SWIreason_ReportException LDR r1, =0x20026 ; ADP_Stopped_ApplicationExit SWI 0x123456 ; ARM semihosting SWI arithfunc ; label the function CMP r0, #num ; Treat function code as unsigned integer MOVHS pc, lr ; If code is >= num then simply return ADR r3, JumpTable ; Load address of jump table LDR pc, [r3,r0,LSL#2] ; Jump to the appropriate routine JumpTable DCD DoAdd DCD DoSub DoAdd ADD r0, r1, r2 ; Operation 0 MOV pc, lr ; Return DoSub SUB r0, r1, r2 ; Operation 1 MOV pc,lr ; Return EXPORT __main END ; mark the end of this file
I got it working. The instructions weren't much help but I kept playing around with it until I got it to assemble and link. Thanks for your help.
