Hi there, I am using the EZ-USB NX22LP-Flex development board, and I need to set up a NAND read routine.
According to the Tech Reference Manual, it requires setting up INT4 as an internal source for GPIF interrupts, using INT4CLR (special function register).
How could I declare the INT4 as a GPIF ISR?
Help is appreciated.
Eugen
