Strangest problem.....HELP!!!!!
I am using a uVision 3 to write a firmware program for a TI chipcon CC1110 chip.
Lately I am having VERY strange troubles with the compiler...
I write a code. And it works great. Then I add a line of code. Any line which has no logic meaning like int k=0; (This isn't a specific example..this happens with ANY line of code,anywhere in the program). Then I burn the program to the chip and suddenly it doesnt work although no logical change ha been made.
Then I write k=0;k=0;k=0;k=0; a few times (don't remember the number of times you need).Then I burn the code again and it works perfect!
I add another k=0; ... it stops working....add some other lines...works fine. IM GOING CRAZY this makes no sense at all!! it seems that the number of code lines needs to be aligned to a certain size.This should not happen.This is not a memory issue for sure since I still have 16K of memory left.
Is this a known keil compiler bug??What should I do??
