hello i'm a new to this microcontroller stuff but i've already built the burner for 89s51 now for i'm not smart on my own i need to have links to existing projects so i could use my microcontroller
well help regard
"i need to have links to existing projects ..."
I have found that Google (et al) supply a preponderance of links. Start there.
1) have you made the circuit with absolutely no substitutions? 2) is every chip decoupling cap mounted less than 5mm from Vcc and Gnd? 3) are all connections as short as possible (I assume "flying leads") 4) This is soldered, I hope, not a pegboard 5) good luck, some have had success with this.
PS what does this have to do with Keil software?
it seems that you are a capable hardware man. what makes you think that downloading an almost arbitrary project will solve your problems? you built the hardware, you are the best reference as to how it should be controlled. so grab a C textbook and your processor's manual - good luck.
