Hi
I would like to know if it is possible to display information onto a hyperterminal display on a PC. The uC is processing data like voltages and temperature and i would like to know how i could print this info on a screen. I'm using assembly language to program the 8051 and would be my preferred option.
I can give more details as needed
As long as the amount of data you are processing is not more than a reasonable baudrate can transfer, then it is possible.
Connect your the UART in your chip to a MAX232 or similar to convert from logic levels to RS232 levels.
Then write code to format your measurements in a suitable way (binary or ASCII) and drop off the data to the UART. Either directly or using a circular buffer with an interrupt.
There are huge numbers of example programs showing how to use the UART.
Small addition: You may want to avoid doing computationally expensive formatting (e.g. by using printf) on the 8051.
