I am using 128K EPROM in my project with 2 code banks. I am also using 64K RAM. The parameters generated as per keil listing file :
BL51 BANKED LINKER/LOCATER V6.15, INVOKED BY: C:\KEIL\C51\BIN\BL51.EXE COMMON {.\output\STARTUP.obj}, COMMON {.\output\L51_BANK.obj}, COMMON {.\output\mic40.obj}, BAN >> K0 {.\output\Line40.obj}, BANK1 {.\output\print40.obj} TO .\output\96v1 BANKAREA (0X2E10, 0XFFFF) REGFILE (.\output\9 >> 6v1.ORC) PRINT (.\Listing\96v1.m51) RAMSIZE (256) BANK0 (?CO?LINE40 (0X8000), ?PR?MAIN?LINE40 (0XFF00)) BANK1 (?CO?PR >> INT40 (0X8000))
The modules are : Common - ?CO?MIC40 Bank0 - ?CO?LINE40 Bank1 - ?CO?PRINT40
LINK MAP OF MODULE: .\output\96v1 (?C_STARTUP) TYPE BASE LENGTH RELOCATION SEGMENT NAME ----------------------------------------------------- * * * * * * * D A T A M E M O R Y * * * * * * * REG 0000H 0008H ABSOLUTE "REG BANK 0" REG 0008H 0008H ABSOLUTE "REG BANK 1" REG 0010H 0008H ABSOLUTE "REG BANK 2" REG 0018H 0008H ABSOLUTE "REG BANK 3" DATA 0020H 0002H BIT_ADDR ?BA?MIC40 DATA 0022H 0008H BIT_ADDR ?BA?LINE40 BIT 002AH.0 0002H.7 UNIT ?BI?LINE40 BIT 002CH.7 0002H.4 UNIT ?BI?MIC40 002FH.3 0000H.5 *** GAP *** DATA 0030H 0020H UNIT _DATA_GROUP_ DATA 0050H 0019H UNIT ?DT?MIC40 IDATA 0069H 0001H UNIT ?STACK * * * * * * * X D A T A M E M O R Y * * * * * * * XDATA 0000H F625H UNIT ?XD?MIC40 XDATA F625H 079BH UNIT ?XD?LINE40 XDATA FDC0H 00C8H UNIT ?XD?PRINT40 * * * * * * * C O D E M E M O R Y * * * * * * *
-- and so on.
Q1. What does ' X D A T A M E M O R Y ' specify in the above listing? Q2. How to manage between xdata variable defining in one module and using as 'extern' in other module.
For example, I defined xdata variables in my project as follows:
In common module(MIC40) header:
typedef struct trunk_def { unsigned char enable; unsigned char id; unsigned char type; unsigned char count; unsigned char on_enable[2]; unsigned char off_enable[2]; unsigned char cs_denied[12]; unsigned char cs_allowed[12]; unsigned char access[96]; }T_GROUP; T_GROUP xdata t_group[24]; typedef struct alarm_time { unsigned char hrs; unsigned char mins; unsigned char secs; unsigned char day; unsigned char month; unsigned char year; unsigned char week; unsigned char alarm_applied; }ALARM_TIME; extern ALARM_TIME xdata alarm[96];
----------------------- In banked modules:
typedef struct trunk_def { unsigned char enable; unsigned char id; unsigned char type; unsigned char count; unsigned char on_enable[2]; unsigned char off_enable[2]; unsigned char cs_denied[12]; unsigned char cs_allowed[12]; unsigned char access[96]; }T_GROUP; extern T_GROUP xdata t_group[24]; typedef struct alarm_time { unsigned char hrs; unsigned char mins; unsigned char secs; unsigned char day; unsigned char month; unsigned char year; unsigned char week; unsigned char alarm_applied; }ALARM_TIME; ALARM_TIME xdata alarm[96];
The structures and variables are created in the modules as per their frequency of usage. Q.How will the compiler handle these? Q.Should both definitions be first defined in common module and be defined as 'extern' in Banked modules?
