Does someone knows if the RL-FlashFS is fully implemented? I am having problems with the storing data on the flash file system. I opened the file with fopen, then wrote some data into it, and close it with fclose. The new created file is an empty file. I am using a MCBSTR9 board. Is there any known issue regarding the MCBSTR9 platform or flash file system on this platform? IDoes anyone know if this is a problem? And a solution/workaround for this?
Could someone from Keil please share some light in this issue?
Thanks, Tom
are you trying to write to an SD card or a RAM drive...? what are you doing?
I am trying to write to the internal flash of the STR912FW44 chip on the MCBSTR9.
