Changing target via uVision Socket Interface
hi.
is there a way to change the project target in uVision3 using the uVision Socket Interface (Application Note 198)?
thanks,
andre
  • Hi Andre,
    Unfortunately this is not possible in the current interface. It is possible to switch between targetting the simulator and targetting a JTAG debugger such as the ULINK2, but not possible to change the target.
    This option may be added in an new release of the uVision Socket Interface, but until then the only solution is to have 2 different projects that can be loaded via the UVSC_PRJ_LOAD() function.
    Regards,
    Richard
  • Hi Andre,
    Regards,
    Richard
