Serial port heros - this is your chance !
Hello all,
Today I made myself a nice and simple serial cable - TX, RX and ground (I don't need anything else), and it works well when I connect 2 laptops to each other, running HyperTerminal. Unfortunately, HyperTerminal does not record serial data sent by 2 different evaluation boards (MCBSTR7/9), running Keil / ST sample code. What can be the cause of this? Can it be related to the type of wire I used? Any ideas are welcome!
Thanks in advance
  • Serial ports on computers are generally wired as DTE (Data Terminal Equipment) while the serial ports on evaluation boards are generally wired as DCE (Data Communications Equipment). What this means is that connecting DTE to DTE requires RX/TX swapping. However, DTE to DCE RX/TX is wired straight thru.
    Jon
    Jon
