I have set my system timers to generate interrupts at 10Hz (MSINT) and 1HZ (SECINT). The millisecond interrupt is triggered immediately after reset but the seconds interrupt takes some time before it starts to trigger (about 15s). After that it triggers every second, as desired.
I have set up the timers as follows:
void InitSysTimer(void) { // Set millisecond timer MSECH = 0x73; MSECL = 0x32; // Set hundred millisecond clock HMSEC = 99; // Set interrupt frequency SECINT = 0x89; MSINT = 0xE3; // Enable interrupt AIE = 0x90; EAI = 1; // Power on system timers PDCON &= 0xFD; }
Is there a reason the seconds interrupt takes so long to be called?
Thanks, Paul
