Dear friends
i would like to know how to send any bit of a char to any port pin ie. unsigned char a = 0xAA; now at memory location for a will contains 10101010b can i send the bit 0 of "a" to P1_0? i don't want to send the entire a to P1
thanking you
sunish
sunish, please reveal to us what you want to do - if you want to send the data to the outside world, maybe you want to interface your UART. Other options are to transmit your byte using "bit-banging" (by dedicating at least one bit for communication with another device), but for that you need masks and shifting. good luck.
thanks for the suggestions
i am not trying to transmit the content of a to any distance. just assume, i'd connected 7 i/o devices to port 1, and just want toggle the status of led connected to the 8th pin of port 1 according to the value of bit 0 of char a. here i need to send the bit 0 of char a.that's what all i need without affecting the status of the other pins of port1
regards
assembler: clr setb C: setb
both are very well documented, assembler in "the bible" C in the Keil manuals.
