Hi, I am trying to impliment file handling operation using web browser. It displayed all the files stored in SD/MMC card alongwith their size ,date and time of creation, total free space on web. We can perform following operations through web application:- Rename a file Delete specified file Format Card Browse the card but fails to craete/read/write operation through web
Regards Pramod
Was that a question, or just a statement?
You haven't spent much time trying to describe in what way you fail the file operations, and what you have done to try to narrow down what may go wrong. We do not know if you get an error code when you try to open a file, or if you get a processor reset or something in between...
You are hardly explaining what your problem is. You should give more technical details about what you are doing and what you want to achieve. Otherwise, no one is going to be able to help you out.
