Am Working on Watchdog timer in P89V51RD2. But Am not getting the result. My code is
WDTC|=0x18; // Enable OUT and Reset WDTD=count; // Load Count to Reg WDTC|=0x01; // Start WDT On LED1 while(WDTC&0x04); // Wait for Flag On LED2
but its toggling always. Actually i have defined the registers in reg52.h file.
Can anyone suggest me how i can solve this problem.
Thanks in Advance.
Regards, Madev
You can use my code to init your program in Keil. Thank You <title> This Code For ATMEL P89V51RD2BN Used Internal Baudrate <emdtitle> /* Start of Config P89V51RD2BN:UART0,UART1 */ SCON = 50h; /* UART0 = Mode 1 (N,8,1) SCON1 = 0x50; // UART1 = Mode 1 (N,8,1) /* Select Generate Baudrate By Internal-Baud */ TCLK = 0; // Disable Timer2 Generate TX Baudrate RCLK = 0; // Disable Timer2 Generate RX Baudrate BDRCON0 |= 0x0C; // TBCK:RBCK=1:1 = Used Internal Buad Generate UART0 Baudrate BDRCON1 |= 0x0C; // TBCK:RBCK=1:1 = Used Internal Buad Generate UART1 Baudrate BDRCON0 &= ~0x01; // SRC0=0 = Select Fosc to Baudrate BDRCON2 &= ~0x01; // SRC1=0 = Select Fosc to Baudrate /* Setup Internal-Baud Generate Baudrate Fast Mode */ /* Support Baudrate : 4800,9600,19200,... ,115200 */ PCON |= 0x80; // UART0:SMOD0 = 1 (Enable Double Baudrate) BDRCON1 |= 0x80; // UART1:SMOD1 = 1 (Enable Double Baudrate) BDRCON0 |= 0x02; // SPD0=1 = Fast Baudrate Generator BDRCON1 |= 0x02; // SPD1=1 = Fast Baudrate Generator BRL0 = 0x88; // Setup UART0 Baudrate 9600BPS BRL1 = 0x88; // Setup UART1 Baudrate 9600BPS BDRCON0 |= 0x10; // BRR0=1 = Start Internal Baud1 BDRCON1 |= 0x10; // BRR1=1 = Start Internal Baud1 /* Start Keil-C51 Transmit Function */ TI = 1; // Set TI to send First char of UART TI1 = 1; /* End of Config AT89C51RE2:UART0,UART1 */ /* Setup UART Interrupt Control */ ES = 0; // Disable UART0 Interupt EN1 &= ~0x108; // Disable UART1 Interupt /* Print String to UART0 */ printf("I AM A PROGRAMER I AM YESEREE BOB From UART0\n");
the purpose of a watchdog is to reset the uC when it is not fed. Thus, when the WD times out it resets the uC.
P89V51RD2BN is from NXP.
The code from u is about UART... Can u explain me how its linked to Watchdog
My Program worked with small modification
WDTC=0x18; // Enable OUT and Reset WDTD=count; // Load Count to Reg WDTC|=0x02; // Refresh WDT WDTC|=0x01; // Start WDT
WDTC|=0x02; // To Refresh before timeout WDTC&=0xFE; // To Stop WDT
May be helpfull
hi, i am happy my code was help for you.
