I'm using the AT89c51cc03 microcontroller and i've compiled a program that i would like to write to it using FLIP from atmel. But i need to create 2 HEX files, one for the flash and one for the EEPROM. In addition the FLIP software gives the possibility to choose between H-389 and H-89, whereas the keil software appears to be only able to create H-389. Could this have something to do with it, because the previous program had to be written with FLIP set to H-89...
So the questions that arrise are: How can you create the file for flash and eeprom. And is there a significant difference between the 2 types of hex files?
Regards Rob
