Wee need an anpplication which can automatically generate a flowchart diagram from an existing C51 code. I found this application called CrystalFlow. Is there anybody who has an idea about it?
Is it worth for buying it or are there any better options?
Best regards
I have CrystalFlow and I use it for documentation for clients that request more detailed documents. I would rate it fair to good. Do not expect a flowchart across your full application but for modules within your application it does a good job. You can select several levels of detail including comments, etc. Any non-standard (ANSI?) code will be listed as comments. I like the feature of being able to edit within the CrystalFlow IDE. I purchased after the eval and I have upgraded one time since my original purchase. I plan to renew my license when it expires this year. Bradford
