LPC2138 Flash Write Problem
Hi
I am trying to write to flash on a LPC2138. I am using Keils sample code with just the sector number and the ram address changed. Cannot get anything to happen other than I must reconnect to device.
Compiling in thumb. Freq=60MHz
Here is the code
Any help appliciated
typedef void (*IAP)(unsigned int [],unsigned int []);
IAP iap_bypointer;
void iap_byfunction (unsigned *cmd,unsigned *rslt,unsigned entry);
unsigned int command[5];
unsigned int result[5];
char Ram_Arry[512] = "Hello World";
char *Ram_Pointer;
void flash_write(void)
{ unsigned char index;
iap_bypointer = (IAP) 0x7FFFFFF1; //set IAP entry address in function pointer
Ram_Pointer = &Ram_Arry;
for (index = 0; index<0x0B; index++)
//Copy data to be written to flash into the RAM
{ *Ram_Pointer = Ram_Arry[index];
Ram_Pointer++;
} Ram_Pointer = &Ram_Arry;
command[0] = 0x36; //command code for "Read part ID"
iap_bypointer(command,result);
command[0] = 50; //Prepare sector ten for a write operayion
command[1] = 10;
command[2] = 10;
command[0] = 52; //erase sector ten
command[1] = 10;
command[2] = 10;
command[3] = 60000; //Cclk == 12Mhz Pll is disabled in startup code
command[1] = 10;
command[2] = 10;
command[0] = 51; //write 512 bytes from address Pointer
command[1] = 0x00018000; //to 0x0000A000 in flash memory;
command[2] = Ram_Pointer;
command[3] = 512;
command[4] = 60000; // see erase comment above
while(1)
