I have a problem with waking the LPC2364 from Sleep mode with an External interrupt I can bring the LPC2364 to sleep mode but I cant wake it when I generate an interrupt on P2-10(EINT0) Its possible to wake it if I set RTCWAKE bit in INTWAKE register (INTWAKE|=0x8000) and generate interrupt on P2-10. What I am doing wrong?
int main(void) { U32 volatile start; for (start = 0; start < 1000000; start++) { ; } os_sys_init_prio(init, 254); }/*End main*/ void init (void) __task { SCS = 1; /*enable FIO*/ os_itv_set (5); /*delay 50ms*/ while(1) { cnt++; os_itv_wait ();/*delay*/ if (cnt==60) go_to_sleep(); } }/*End init*/ void go_to_sleep (void) { FIO2DIR &=_ZEROMASK(1, 10); /* set P2-10 as input*/ VICIntEnClr |=0x00004000; EXTMODE |= (1<<0);/* EINT0 - set as Edge sensitive */ EXTPOLAR = 0; /* EINT0 polarity : falling edge*/ PINSEL4 = _ONEMASK(1, 20);/*select pin as EINT0*/ PINSEL4 &=_ZEROMASK(1, 21); VICVectAddr14 =(U32) int_extInt0; VICIntEnable |= 0x00004000; /*(1<<14)*/ INTWAKE|=0x0001; PCON|=1; //(1<<0)|(1<<2)|(1<<3);/* first go to Idel Mode*/ for (i = 0; i < 1000; i++); /*short delay*/ PCON|=(1<<0)|(1<<7);//129; /* go to Sleep mode*/ } /* End go_to_sleep*/ void int_extInt0 (void) __irq { EXTINT |= (1<<0);/* Clear the interrupt */ INTWAKE|=0x0001; PCONP|=0xFFFFFFFF; Power_On();//init_power_pins(); VICVectAddr = 0;/* Ack the VIC */ cnt=0; }
