Hi, I am in an urgent requirement of incorporating an array of unsigned char [100][100] lookup table for calibrating a sensor data, into my program. The data is available in the form of a MS Excel sheet/txt file. After compilation, I wish to have the data to be there along with the hex file, and of course my program should be able to read the data from any element of the array.I searched for an example in Keil compiler manual, but i couldnt find any. Please Help me, its so urgent.
So just get Excel to "export" it as a .c file that defines and initialises the array. Use a Macro
Thanks for your valuable information. Could you please attach a piece of code doing the same. Assumed that .C file is now with me. I have made it as you said it.
no code required. either save it as comma delimited text then add the C parts. Or add the C stuff to the cells then copy and paste it. If you want code there is always VBA.
Well, it's not the job of a compiler (or even an IDE) to convert arbitrary file formats into C arrays.
That's what export functions (of the program that generates the abovementioned file format) are for, or scripting languages (VBA, perl, python, Matlab/Octave). If it needs to be automated. If you're only going to do it a handful of times, it may be the fastest to do the conversion manually.
