RTC RAM problem of LPC2378
Dear all
I am storing some variable(normal variable, unsigned char ,int, float ,char Array etc.) in RTC RAM.
After some time processor stop execuation.If I delete all RTC RAM variable from program,and downloading hex file again.but still it is not working.
what will happened? How can I erase RTC RAM?
waiting for your reply...
Shyam T
Pune India.
  • Are you powering the battery-backed RAM?
    By the way - if your program keeps variables that should survive a power loss, you must also write your application so it can detect if the RAM has valid content. There is no configuration bit available that will magically tell if the RAM has been initialized or not, or if the power loss has been too long so a supercap has discharged too low.
