Basics:
When I attempt to enable Timer 1, RTX51 Tiny no longer will task swap.
Details:
- RTX51 Tiny running in Round-Robin Mode utilizes Timer 0 - Attempting to implement use of UART0 utilize Timer 1 as baud-rate generator as soon as Timer 1 is enabled, RTX no longer executes normal task swapping
Timer 1 initialization: // Turn Timer 1 OFF // -------------------- TR1=0; // Disable pertinent interrupts // -------------------- ET1=0; // DISABLE_TIMER_1 ES0=0; // DISABLE_SERIAL_0_INT; // Define timer 1 mode // -------------------- TMOD = ( 0x20 | (TMOD & 0x0F) ); // retain definition of Timer 0 // then define Timer 1 // .7: Gate=0b: T/C enabled when TR1=1 // .6: C/T_=0b: timer clkd by internal clk // .[5:4]: Mode=10b: 8-bit auto-reload // timer for baud generation. // .[3-0]: Timer 0 defs // Configure Timer 1 for baud rate generation: // ------------------------------------------- // Crystal Frequency: 36.864 MHz // Timer 1: Mode 2, SMOD=0 // TH1 = 0xEC delivers 4800 Baud with 0% deviation TH1 = TL1 = 0xEC; // Timer 1 reload values PCON &= 0x3F; // PCON.[7:6] = SMOD0:SMOD1 = 0 // No baudrate doubling for UART0 or UART1 // turn serial port on // -------------------- // Port 0: SCON0 = 0xE0; // 1110 0000: mode 3: asynch, 11 bits, 1 stop, // 1 start, (Even) Parity // SCON0.7: SM0 1: (mode 3: asynch, 11 bits, // SCON0.6: SM1 1: timer 1 or 2 baud rate equation) // SCON0.5: SM2 1: RI active when 9th bit = 1 // SCON0.4: REN_0 0: UART reception disabled (for now) // SCON0.3: TB8_0 0: 9th transmission bit // SCON0.2: RB8_0 0: 9th data bit that was received // SCON0.1: TI_0 0: Transmit Interrupt flag. // SCON0.0: RI_0 0: Receive Interrupt flag. // turn individual interrupts on // -------------------- ET1=1; // ENABLE_TIMER_1_INT ES0=1; // ENABLE_SERIAL_0_INT // Turn Timer 1 ON // -------------------- ET1=1; // ENABLE_TIMER_1
Results: After the ET1=1 is executed, the 2nd task of a total of 2 tasks never goes READY and the system stays in the boot task. I can't detect any where in this timer initialization code that could impact the RTX environment.
Can you detect something that is obvious that I'm overlooking?
