User code highlighting, is it possible?
Is there a tool that would allow the user to highlight a section of code manually for on screen analysis? When you make a syntax error, it hightlights the error, I'm talking like if you have a few code blocks/lines and you want to fill the back of the block so that line sticks out for reference and then obviously be able to toggle it off.
Right now I print out the code blocks and manually highlight the lines in question which helps me solve the variable issues I'm looking at. I searched the help file "highlight" and it just returned the automatic highlighting for syntax.
I wasn't sure if there was a plugin that someone knows about since people develop modules like I2C and such.
