SRAM Test
I am using CY62256 SRAM in my project. I use approx 30K of this 32K RAM for xdata.
Upon system startup, RAM check is done by the following piece of code. Is it
the right way to do, or more and more techniques have to be followed?
#define  xbyte  ((unsigned char volatile xdata*)0)
unsigned char RAMCheck(void)
        unsigned char i,j;
        unsigned int no;
        for(no=0;no<0x8000;no++)     //check the RAM 0x8000 locations (0-32K)
                i=xbyte[no];
                xbyte[no]=0x55;         //write 0x55 & read it & check  whether correctly written
                j = xbyte[no];
                if(j != 0x55)
                return 1;
     //if no then return 1 which will cause CPU to stop here and resets the controller
                xbyte[no]=0xaa;         //similarly write 0xaa & check by reading it
                j = xbyte[no];
                if(j != 0xaa)
                 return 1;
                xbyte[no]=i;
        }//HERE, 1 IS RETURNED IF A SPECIFIED LOCATION FAILS TO READ THE VALUE WRITTEN
kindly advise..
  • continued...
    * How to do non-destructive RAM test if I am using 32K SRAM with 30K data usage?
    * What are the popular and successful SRAM testing methods?
    * What are good RAM testing algorithms for testing 32K SRAM's?
    * How to do a more thorough SRAM test (32K) at the expense of speed/time?
    * RAM flush methods (CY62256 SRAM) I am using: a) shorting VCC and GROUND (In power Off Condition)
    b) Stuffing 0x0000-0x7FFE with 0
    Are both same?
  • continued...
    Are both same?
