How not to get the reset vector?
How do I get uvision3 to NOT put any code at the reset vector? i.e. completely leave 0-7FFh alone.
The reason is that I want to build only the application part of my program and exclude the bootloader segment that lives between 0-7FFh. The map file shows that indeed everything in the application is where it should be, except the compiler keeps trying to save me from myself and sticks an LJMP at 0x0000 - which I don't want.
How do I keep the C_STARTUP segment from being part of the build?
  • Gene;
    Others are more familiar with the Keil C51, but I remember in the startup.a51 file there is an assembly statement such as CSEG AT 0. If you do not include the startup file, default code for startup is still loaded.
    Also, on the Target -> Options -> C51 dialog, you can move the interrupt table but you can't move the interrupt vectors. Remember, they are in the device firmware. Moving the interrupt tables only creates a LJMP to the new vector table.
    Bradford
  • Gene;
    Bradford
